starting problems te310 2012
nep2012
My 2012 te310 has sat for two months. I decided to start it to run it for a while to keep things lubed up no luck. Turns over fine but will not start. Cold in NJ so I am sure this has something to do with it but never had this problem before. I am thinking maybe the gas is bad, Is this possible that the gas goes bad in 2 months and will cause it to not start?
Have had sea doos sit all winter with gas in them and fire right up in the summer , is it possible for an injector to get sludged up , I am sure some of these pros will have the right answer , do you have a spark , good luck.
Got it started. Drained the gas and put fresh gas in the tank. Had to push it and it sputtered back to life. If it starts right up today I'm heading to the pine barrens. Can't miss todays forcast of low 50's.
