Stator Cover Bolts 2 long 4 short but which ones go where?? 310 TXC 2013
Mike Mclennan
Ok well the parts diagram shows a nice schematic, actually showing two bolts the top one is short the bottom one is long,,,, so where does the other long one go..... Anybody know.. As the the length of all the stator cover "depths" is all the same...
After another hour of searching I find a workshop manual that says tighten the screws, but not again which ones are which.
Okay, thanks will do that way, the image shows the bottom one as going where the locating dowell was so I kind of thought this was probably the case but best to check. THX
Assuming that my TE310R is the same as your 250 . . .
I had mine off last week to solve the oil leak from the alternator wires
You can't go wrong with the 2 longer bolts - just put one of them in each hole - the right ones will be obvious as the bolt will go much deeper.
That's the way I did mine anyway!!
Mike
one person also stated on a forum the long one goes at the top, so with the image showing the bottom bolt being the longer. This also coincides as stated above with the guides being on those two holes (top and bottom)
