Erick Gutierrez
So... I've repaired steel and fiberglass tanks from other makers. Normal dent pullers, plus body fillers, sanding and patience is all that is needed. Huskys present a different problem. The metal is showing. What do you do? I have experimented with bronze, it doesn't work since it is harder than steel so a file grabs more of the good surrounding steel that the bronze and makes a mess. I've been told that you can chrome over solder that melts over 500 degrees F. So that would be an easy fix. I've wondered about weird stuff like filling a tank with sand then heating one spot with a torch (the sand would allow just one small part to really get hot) then simaltaniously adding air pressure. Haven't tried that yet- probably blow myself up. I read about someone freezing water in a tank. As the water froze and expanded, dents were pushed out- apparentely the tunnel was also distorted.
Does anyone know how to fix a tank themselves???
