Steering lock 2009 TE 310
Bryce Gill
Hey guys just wondering if any one has had trouble with the steering lock being locked in the key comes out and goes in to the locking position but won't pull the pin out of the steering shaft if you have any ideas would be good
Thanks
This started happening to me just few days ago. All I could do was fill the keyhole with WD, I then turned the lock to where it would normally be in an "unlocked" position and reef the bars from left to right and it eventually popped out. I haven't found a solution yet either.
It is really easy to remove as I found out. Use a screwdriver and lever off the cover. Then insert your key and turn and pull, it should all come out.
