Steering Stem Nut and retaining collar torque
Jimmy250
Hi all , replacing the steering stem bearings on my Buddy's 2011 TXC 250. I found the Nut torque in the manual, my question is for the retaining collar. What is the tightening procedure and/or Torque for that Collar? Any Help would be appreciated. I saw one thread that said make it snug as to seat the bearings and then back off a 1/2 Turn? Is this correct? Thx! Jim
You'll get a better answer here I'm sure from the real mechanics on site but I always have the wheel off the ground and just tighten the collar and check for removing all the slack from that shaft running through bearings by pulling on the front tire ... Any bumping feelings and the collar needs to be tightened more... I'm doing the same thing now to a bike ... Seems I always fumble through the process but make it work out ok ...
