Stray 1981 430 XC Adopted
steve1970
This bike sort of fell into my lap recently (as money left my wallet). Found it through a friend. I definitely didn't need another project but the price was right and the bike is pretty complete. A quick inspection revealed a few things.
- Front end was badly misaligned but the fork stanchions looked straight. Front wheel was pointed about 15 degrees to the right. The bars were also visibly misaligned with the fork caps as a visual reference, bar clamps were crooked in the triple clamps.
- Tank had a good layer of high quality aged desert lacquer in the bottom.
- Carb gummed up (not surprised)
-Had oil in it, didn't smell like gas and no sign of water or moisture (surprised)
Spent a little time this week at night cleaning a few things and checking it out. Has compression but seems low at 110psi. Has spark. Carb cleaned up nicely after a soak. Tank was not as bad as I thought, I poured some carb dip in there and shook it around and it cleaned right up after 15 minutes or so. Rinsed it out real well since the carb dip isn't good for aluminum long term.
I loosened the entire front end up and pulled the bars off. Did my best to align things and retightened. The front wheel was now pretty straight. The grommets in the top triple clamp that isolate the bar clamps were pretty rotten and crushed in a way that indicated a hit to the bars. Then found a circular weld that had been ground down on the left side of the bars just inside the brake lever but before the crossbar joint. Who knows. Maybe the bike went down hard and someone quit midway through sorting it out.
Not sure where I'll go with this bike yet. My 430 CR project needs my spare time so guessing I'll just do easy stuff on this one as time allows and decide down the road where to go with it.
So after all this did you try to start it?
Tank looks great inside but that right side looks like tinfoil thats been crumpled and then attempted to be smooth it out. Based on the other parts you found misaligned and the welded bars it looks like someone who road it wasn't afraid of crashing.
Sure is a good looking husky though.
I think you're right, the side of the tank looks like a repair attempt. It's funny, certain parts of the bike look to be in great shape but others have been through a hard life. Not sure if I'll try to start it at this time, if I decide to I need to order a carb kit and an intake manifold. Carb is clean but all seals/gasket shot. Manifold is crumbly and dry.
