Tank fitment (pics)
2wheeler
The tank pads and fuel line orientation looks like it did before removing. But is it right?
If it fits it's right. Will the tank rubbers sit on the frame or is it held up like in the photos? If so then it's wrong and move what's in the way. :popcorn:
Rubbers must rest on frame, this happens to me from time to time, I just keep moving stuff around until it settles, rubber grommets to frame
Thanks guys. The grommets do not touch the sub-frame. The fuel line is between the tank and the frame section that goes left to right. A few wires are under the fuel line. Looks like I need to rotate the tank elbow to point more toward the engine and reconnect the fuel line.
Initially thought it appeared like the gas elbow was angled back but hard to decipher in the photos. Yes angle forward. It's still is a tight fit and pushes against the cables and such but should have the hose angled a little forward and right over the throttle cables and loop to the left to the TB.
