Kutis
Hi there
I searched the forum but I couldn't find my answer. OK my clutch (magura) went weak so my first thought was air in the system. After endless bleeding I started to go into more details.
I tried to bleed the system bottom to top with no luck.
I decided to take it apart master cylinder, hose, slave cylinder to check for any problems.
I wanted to test master cylinder by disconnecting hose and see if fluid is squirting from the connection... result nothing.. It pushes air out and creating vacuum when coming back but it's totally dry inside. Obviously with full reservoir.
The piston is moving all the way and I can see a small gap where liquid should flow in but nothing is coming from the other end.
Now do I have the wrong end of the stick or I need a new master cylinder kit? Should the fluid be floating out when disconnected?
Thanks guys for response.
