TDC ? Help me
tonycar107
I am assembling my engine for the first time and this is as close as I can get the marks to line up. This at tdc. The manual is kinda vague when it comes to this. Can anyone please help me out and let me know if this is ok. I can also move the chain one link on the gear and it will end up a little off on the other side.
Thank you.
FYI - I put it back together today and all went well. The manual says to set it at tdc but from the picture above to where the notches line up is 0.09 mm in piston movement back down. That is what was throwing me off, but it runs fine, so oh well.
I've seen this in car engines, its caused by the combination of
sprocket wear and chain stretch. On a car it will set a cam timing
code, usually with no drivability complaints. To confirm you need
to measure the pin to pin distance on the chain and measure the
sprockets valley to valley straight across the center line, I'm not
sure if husqvarna offers these specs. But you may be able check
the measurements against new parts at the dealer.
