TE 250 '10 frame wear guards
rockdancer
Want to tidy up my bike
Anyone seen any upper frame guards or know if you can successfully patch paint the wear marks ?P1010039.JPG
Husky make them as an official aftermarket part. Come in white or black, I fitted some to my 310 from new as I thought it could be a problem area.
What I don't understand is why they don't just make the original guards twice the length to stop this problem occuring.
you can get them from husky in white or black and are around $40.00
i have some thay work worth getting
part no.. 8000h2210 white
part no.. 8000h2211 black
Here they are...they are a little cheap but seem to work. They zip tie to the frame. I glued them for good measure.
If you glue them could that not ruin the paint you are trying to protect? If you just don't want to see the wear marks I get it. makes sense. I will order some thanks for the part numbers.
In regards to glueing them on the frame...the part is thin plastic and did not look that secure with just one zip tie. You will have to make the call when you install. The product works to protect the frame but in my opinion it is not high quality for the money. Grip tape may be another alternative to ptotect the frame.
I cut some carbon fiber decal material and put on mine, it looks good and is holding up. I may buy a set of those guards and see about making some out of carbon fiber.
GP
