te 310 oil in air box
Maybe you are over filling the engine with oil. 1.7 litres is the max recommended amount. Oil can also come back into the air box after a fall, especially if you fell onto the right hand side of the bike. Even more so if the bike was on ots side for a while.
I use to see it when the bike was new. Now that i have some miles on it i dont see it any more. Or i just dont fall on the right side.
try using 1.5 litres instead of 1.7 ....... this is very full with 1.7 liters as long as your oil level is between the 2 marks in the glass window your ok i use 1.5 litres never had a problem........ and try to not drop the bike on the right side
Interesting point husky bom. Thinking about it I would still go for the 1.7 litres as it gives more fluid to dispense engine blow by sludge, clutch contamination etc, helps the scavenger pump too. A nearly 12% reduction in oil, esp for our Australian conditions might be a bit of a stretch me thinks Bom.
