te 310 problem
kalina75
Hello.
I'm from Poland. I have te 310 IE EU version 2010 ( Marcochi 50 mm). everything ok, bike working super. only problem it happens when push cloutch lever while driving, when the engine goes out.
we checked TPS, fuel injection,e
electric coil and ECU in the second smooth TE 310. Symptom it is the same. While gas open, and reduction rpm without cloutch working ok, no go out. I have no idea what's next. Someone has answer :(
Sorry for my language...
Think this one is for a husky mechanic Kalina. Sorry we have not got an easy solution for you Mate.
Isn't there a safety switch on the clutch lever so that when the bike is in gear you have to pull the clutch lever in to be able to use the electric start? Sounds like an issue with the swicth.
Look at your banjo fitting on your clutch lever. If like mine, there may be a wire that connects to a switch coming straight out of the banjo bolt head and then the fluid fitting that angles down and out the side as normal. It may be simple enough to replace that switch on the clutch end and the re-bleed the line.
My parts pdf shows it as #8000 H5963 1 Idrostop
