te 449 ecu location
Remove seat. Forward of the battery is a black box about 4"x4"x3/4" thick. It's strapped to the frame with two rubber loops right above the top shock mount. Carefully using a small flat screwdriver pry the rubber loops off the steel mounting tabs on frame. It's got a big multi pin plug attached. Unplug, box and send.
