TE 449 Engine won't return to idle
Matt Rotin
Im not sure if there is already a thread about this but it seems to be a common problem with these bikes. During a ride, when you have to shut the throttle off to negotiate a situation, the engine will hold the throttle slightly on which can make for some entertaining situations. I am used to it now but would rather it not be there. Just hoping someone has figured out the cure.
This old advice worked for me:
TPS Quick Reset
- Fully Warm Motorcycle
- Disconnect the battery for approx 2 minute, then hook it back up again.
- Turn the ignition key on.
- Turn the throttle to full stop and then back again.
- Turn the ignition key off, wait 5 seconds, and then turn it back on again.
- Start the bike without touching the throttle.
TE511 Air Bypass EFI Adjustment
- This is the big brass screw high up on the side of the EFI body
- 2 ¼ turns out for a TE511 (+/- 1/8th of a turn) should put the minimum air bypass back in range.
- It is the only screw on the throttle body that should, or can, be touched without major drama.
- If the screw is too far out it will push you into a corner like having the throttle open a bit.
I will be surprised if these 2 procedures do not help. Do the TPS reset twice to be sure.
Also, just a thought but take the EFI cable cover off the side of the EFI main body and check if all the cable adjusting screws are tight and that the cables wind around the cam correctly through its full range of movement. While you are there you might as well check for the correct cable backlash/freeplay. There is a section in the owners manual that touches on this.
I had same two years ago. Too high idle rpms. Turn big brass screw on throttle body.
Try the simple stuff first and work from there. The procedures listed by Gillies are quick simple and free. I wouldn't go removing the butterfly yet until you've exhausted the other possibilities.
Thanks for the info guys, ill let you know how I go, great bike by the way, its a crying shame it didn't see a few more years of development.
