te 449 forth gear problem
dale ogden
  1. hi my bike runs relay bad in forth gear its fine in all over gears but it seems to miss and splutter in forth ,anyone had this problem ? i have checked the fuel pump and the wiring to the plug and it all seems fine ,i am thinking of getting a jd tuner do you think this will solve the problem help please thanks
Could be a "flat spot" in the mapping. Suggest after market tuner, or upgrade to map3. You could try a TPS reset first.
hi thanks for the reply i have done the tps reset will have a look into map 3 were can i get this done in the uk?
