coleman1495
Okay so I am the not so proud owner of a 2013 TE 449. The bike for the most part runs good (except for dead throttle from time to time). Unfortunately I have run into issues when the bike is hot.
A few days ago I went on a ride through a tight forest area. It was a fairly hot day (~27C) and I was seldom able to get the bike out of first gear. Initially the bike was fine but after around 10 minutes the bike started stalling. I had to constantly give the bike throttle and pull in the clutch in order to keep it running. I continually had to keep restarting it and had to get out of the woods ASAP. Once I got back in the open the bike had no problem and returned back to normal (more air passing through the radiator allowed the bike to run cooler). It occurred to me that I have never operated the bike in such a tight area before and therefore never experienced this problem.
The coolant level on the bike is fine. The electric fan is working. The bike will idle when parked although the idle RPM is significantly increased. Operating the bike is nearly impossible though. You have to rev the heck out of it to avoid stalling. Combine that with the fact that first gear is stupidly fast (Did the geniuses at BMW ever demo this bike anywhere but a pretty little test track in Germany? How is going 20km/hr in first gear okay? Arghh!) The bike usually lugs pretty well in first gear but wont when hot. I am assuming that the bike should be capable of operating in these conditions.
I searched the threads for a solution and am not sure what the best course of action is. The bike so far has the race jumper installed and the stock muffler has been decatted. I was thinking of maybe removing the secondary butterfly or getting a PCV. What do you guys figure? Has anybody else found that there Husky does not run worth a darn when its hot?
