addo
View attachment 13514View attachment 13515 View attachment 13513
I purchased a Husqvarna 2008 TE 450 4 days ago in almost new condition, but had noticed a slight hesitation under hard acceleration, not thinking much of it I had a service carried out by the dealer as its carried out 555 miles and 27hrs from new. The dealer didn't picked up the hesitation but changed the oil, oil filter, spark plug, air filter, de-compression cable and the two exhaust shims as they were out of specification. So I went out on a ride yesterday as I'm planning a 100 mile trail on Sunday to make sure all was well.
It fired up well and for the first 4 miles no problem but the hesitation was there but not when you accelerated normally just under full bore. I then rode up a slight incline and the bike just stopped? i tried bumping it and using started motor but no joy. a friend drove out in his van and recovered it and i rolled it into the garage scratching my head. I went through the ignition sequence an noticed the fuel pump wasn't priming so stripped the tank down and noticed the earth was disconnected!
Here is the Fuel pump when i removed it, as you can see the earth black cable is off and the reserve sender has snapped off
! firstly it started instantly without any choke within a millisecond unlike the usually 0.7~ 1.3 second turn over, I let it warm up abit and gave it full bore and the front wheel lifted 1st, 2nd and 3rd! power was stronger, faster and more relentless giving the power a linear feel and the gears couldn't have come fast enough.
