TE 450/510 main bearing "groove" size
Zeppo
Does anyone know the size of the grooves in the 450/510 main bearing?
One of my friend is able to do the grooving if I have the measurements.
It cuts down time if I have bearings ready when I start overhauling the engine (530cc +balancer).
Probably the best route would be to take yours out as a model for your friend to use. You could remove them give them to your friend and he could turn them right around to you. No waiting for parts to arrive with just a day or two wait for your friend. You could also measure the thickess of the bearing retainer.
Yes I know I could do it that way and I will if I don't get the measurements.
I'm taking the engine to a workshop so it would be a good thing to have the bearings ready.
George at Uptite would know. He machines the groove in to FAG bearings because he believes they are of higher quality than the OEM main bearings.
