TE 450 Freewheel Clutch
Tetley
WP_20150307_001.jpgWP_20150307_002.jpg When draining the oil I found shards of metal on the drain plug magnet, so I took the clutch cover off to find out what's wrong.
In the botton was half a large circlip type thing, and a loose disc of metal behind the freewheel clutch.
The problem now is I'm not sure how all these parts were originally assembled, as the workshop and parts manuals show just a thin metal disc which goes between the freewheel clutch and sprocket behind.
Can anyone make any sense of this?
I also need to find the other half of the circlip type thing, which must be in the gearbox, so engine out and totally rebuild.
I found out what happened - The sprag clutch edge had worn away so much, it no longer had any holes to keep the tags of the circlip located, so it just popped out. It then forced off the retainer disc, mangling the 4 tags, before falling into the gearbox to be destroyed. Engine now apart, and no other damage done :)
