te 450 headlight bulb problem
mfp
I have a new TE450 and in the last couple of months, I have blown 5 headlight bulbs......
I figured the first one was rough trails. then second one i touched it with my finger and figured the oils made it blow. the next three....i cant figure it out.
The bike is brand new. This should be a warranty issue, right?
I got a volt meter and i am reading 15 volts to the battery and headlight. Maybe the voltage regulator is out?
I cant get an answer from the dealer.
Has anyone else experienced this??
its a crappy bulb design, its also dim as hell... Buy a new/better light. motosportz.com Sells a nice replacement fore cheap. I just decided to gear my bike for motocross. But the light on motosports is perfect.
If you change out your light dont go the Baja Designs H4 route expecting it to be a breeze. I have the BD light on my TE. The stock straps are way to small. Had to use the stock '08 50mm Zoke straps to fit it. I was just barley able to get them poked into the shell after enlarging the holes as much as I could with the material available. I will try the UFO Ray halogen the next time around.
15 volts might be a concern. It's not uncommon to see 14.7 charging to the battery. If the voltmeter is off a bit it could say 15 and be fine. But it sure would make me suspicious if I had blown 5 bulbs!!! That's a bummer.
Dan at Motoxotica sells a better (IMO) replacement bulb for cheap that puts out just a bit more light anyway (it's 45 watts instead of 35 watts). I've had one of those on my 09 TE 450 for almost 1000 miles now.
I was losing bulbs too fast as well so i go to a KTM guy i know and he sells me a bulb that ends up melting my headlight housing so now i need the whole friggin headlight, not just the bulb. I went to the motorsportz.com site and didnt see one. Anyone have any other suggestions for a reasonably priced AND better-than-OEM headlight for a 2009 TE450?
