bungarra
I need some help with what to do with my 09 te 510. I bought some B&B offroad heat shields as the standard ones are either s-house or non existant. http://www.bboffroad.com.au/husky_te250_310_450_510_08+111.htm The rear gaurd to cover the area where the pipe goes into the header has fixed most of the issue.
The big prob is that one of the hex bolts snapped off that hold the front gaurd on when I went to swap this over. Not only that but so did the easy out after a half hour of patiently drilling out the bolt.
So now do I either grind of the other bolt (it wont budge either, it's had a fair bit of persuasion as well) and heat wrap the mid pipe. Or is there another gaurd that mounts onto the pipe without the use of the original mounts, e.g. the p3 carbon one. I would prefer not tho wrap it as I dont want it comming unravelled in the sticks.
Cheers
Bungarra
Cheers
Bungarra
