Interesting development Helmut.
I've always assumed that the secondary TPS doesn't register as a fault if between the 'normal' voltage ranges, I guess this confirms it.
I thought this through when I had my 'dead throttle' experiences & did not have a fail message appear.
(In an automotive system, this would certainly leave a fault code.
If a device like a fly-by-wire throttle is used, it usually has two systems of monitoring the shaft movements.
The ECU uses these signals to confirm that the butterfly turned to the requested position).
In the case of the TE449/511 secondary butterfly, this clearly is not the case as numerous bikes have experienced the 'dead throttle' where the electric
butterfly does not open when the primary throttle is moved. Certainly on my own bike, this left no fail message in the ECU.
It would seem likely then, if what you're saying works, that you could fit the TC throttle body, use the old stepper motor housing (secured somewhere out of the way) & secondary tps setting you mention, & be able to utilise the TC fast idle/hot start knob the throttle body is fitted with.
Cool![]()
I had many dead throttle experiences before the BF removal and zero fail indicators.
