Hi all, I checked my valve clearance today and was after some help from the people in the know....
Bike is a 2013 TE511, with about 2,200 Km done. I service it (Oil and filters) about every 350-400K's, full synthetic used after 250K run in.
I rotated the engine to TDC using the two dots on the timing gears pointing to each other as a guide and measured from that position.
Left Inlet is .150mm
Right Inlet is .178mm
Left Exhaust is .203mm
Right Exhaust is .229mm
From my understanding, both inlet and exhaust are out of spec, inlet with too much play, and exhaust too tight..
Should I be concerned about this? I've read on here that heaps of people haven't needed to adjust their valves ever.
Thanks.
Thanks.
