TE 511 Yoke Torque Specs
Cosmokenney
Just pulled the forks to put in new springs. Now I can't find a torque spec in the manual. Nearest I can find is the general section of section X in the workshop manual. I'm assuming the yoke bolts are M6? So the general section says:
Steel screws on brass, copper, aluminium M6 6.5 Nm 0.65 Kgm 4.8 ft/lb
Doesn't 4.8 ft/lb seem a little light?
Not really I think 4.8 would be about right and 11 for the uppers? I recall I followed the XTRIG specs for my clamps (aftermarket husky clamps) as I have double the bolts.
"If any play is detected, adjust as follows: - Remove the saddle; - Loosen the steering head tube nut (1); - Loosen the two bolts (3) that secure the fork legs to the steering head; - turn ring nut (2) on steering tube clockwise using the suitable special wrench, until obtaining correct clearance; - tighten the steering head tube nut (1) to 8-9 Kgm. (78.4-88.3 Nm); - Tighten the four bolts (3) on the steering head to 22.5-26.5 Nm (2.3-2.7 Kgm)"
The picture shows 3 as the triple clamp bolt. That seems high but possible.
Honestly as long as the top is tight and the bottoms are not TOO tight. You want them to flex and give in a crash in my exp. Also the lowers tightened too much will cause stiction and wearout the sliders and stuff. I dont think any bike has much tension on the lower clamp bolts. That is why aftermarket clamps have more surface area and several bolts (3 or 4 even) to clamp lightly but snug.
Sorry I cant be of more help!
