capt42104
Hey all!
With CJ’s permission, I have created this post….Sorry if it is long winded…
I just wanted to give kudos to CJBROWN(Chris) for his brilliant TE 630 sub-frame support mod. After coming from a KTM LC4 (02-22k miles), BMW GS 650 (03-46k miles), KLR 650 (05-36k miles) of off-road adventures, I was drawn to the TE 630 because I wanted to tackle some more difficult terrain with confidence and safety of a more off-road designed bike. As I was setting the TE up to adventure ride, one of the first things I put on, after the 606s, was a rack (Tourtech, same as Husky brand now).
As I was installing the rack I noticed the rear sub-frame is horribly inadequate for any sort of real world loading (tools, fuel, oil, inner tubes, clothes, etc.). I figured I would wait for it to break as no one was really complaining of failures on the TE 610s or Te 630s yet. Even though I recalled the KLRs where notorious for cracking and shearing the bolts with loads or not, I assumed the TE’s design was time tested with the 610 and SM 630. But I was wrong; there was the post on a broken sub-frame. Game over.
CJ was quick to recognize this weakness and posted his idea. See:
http://www.cafehusky.com/threads/new-rack-for-te630-coming-from-turbo-city.20567/page-3
With a simple PM he provided me some advice from his mod experience AND his detailed drawings in PDF. Coming from the KLR/BMW adventure community I was used to this freedom of sharing, but only from guys I rode with, not on forums. This was a great surprise.
As I am on a two month hiatus from surgery, I took this time to tackle this mod myself as I will be doing some Cen Cal Sierras and Death Valleytreks in January. Total time was about 4 hours.
I decided to follow CJ's advice and used aluminum as the support braces. I decided to use some 3/16” x 2” aircraft structural 6061 aluminum for the braces and used cold rolled steel (soft) in the same size for mock ups because the steel is actually easier to work with and it is cheaper (readily available from Lowes, Home Depot, and OSH). Once I made the steel braces, I used them as mock ups and templates for the 6061. Amazingly CJ’s PDF drawings were very close to what actually fit my bike (the holes were a little off). This is due to the differences in the manufacturing frame tolerances and welds I am sure. I seriously recommend mocking up first.
I had some scrap 3/16"x 2" 6061 flat stock from a RV4 kit plane project, and used this spec 6061 aluminum for its structural traits and light weight. You can find this available in small pieces from “speedymetals.com” at a great price. Most of the local hardware places only had 1/8” non-structural aluminum and plenty of 3/16” steel. You must use structural 6061 aluminum IMO! The steel is almost 2lbs heavier than the 6061.
Basically,
Remove all the rear end plastic and rack from the sub frame as well as the fuse/relay box, fender liner. You may need to removed the mid pipe and exhaust if you still have the CATs.
Cut the braces using the template and mark the holes corresponding with the rear grab handle mounting holes and u-bolt locations (just rear of the seat lock on the left side and rear of the right side regulator box). Fit them and punch the mounting holes at the rear and where the u-bolts will be. Drill holes.
Install finished brackets and tighen it all down to verify the bolt holes are right. I had to put a slight bend to curve the braces just fore of the front grab bar mounts to ensure a flat fit at the u-bolt and rear mount (maybe 2 degrees).
Mark the frame where the u-bolts are remove the braces, install the fender liner and mark and cut your fender liner. You will need to cut 1/4" slits from the rear at the 90 degree bend where it flares out to accommodate the braces. I had to cut about 4-6" right down the 90 degree bend. Keep sliding the braces in and only cut just enough to allow them to fit. I used a Dremel tool to do this. Re-install the u-bolt to mark the access locations on the liner. Remove the liner and use the hole saw to cut the u-bolt access holes. This will allow you to tighten the u-bolts after you install the fender liner. 4-holes total. Again, remove the liner and drill the holes.
Once the holes are drilled and cleaned up, re-install the liner, install fuse box, install the braces, loosely attach to u-bolts, install rear plastic and grab bars and run the bolts through the braces. I needed to buy 1/2" longer stainless steel hex head bolts to accommodate the braces. Tighten the rear attachment point at the grab bar mounts first, then the u-bolts (i needed to install washers between the u-bolt and the brace to make a solid fit). I then trimmed off a little of the rear grab handle mounting bolt because it was protruding past the nut to ensure clearance.
Use black silicone to create a seal along the fender slots and the 4 u-bolt access points. (I apologize for the eagle turd silicone job, but hey, this is an adventure bike not a show bike!)
Parts/tools needed:
CJ's template, PM him
Sharpies pen
Punch
1-3/16"x2"x12" Alum 6061 (and steel if you want to cut twice), right side
1-3/16"x2"x18" Alum 6061 (and steel if you want to cut twice), left side
2-U-Bolt, P/N-8000 71091, (It's more of a bracket looking thing used to secure rear foot rest assembly to the sub frame.)
4-Screw, P/N-8000 69056, (Screws used to secure bracket to the U-Bolt clamp.)
Drill and bits, 1/8"-pilot holes, 5/16" for the finished holes
Dremel tool
Bench Vice and Bench grinder
Saws-All, good jig-saw, good bench cut off tool, belt saw
3/4" hole saw
Thread locker for ALL fasteners
4-Stainless Steel Bolts, nylocks nuts, and 8 washers (all stainless)-optional if original bolts are too short to accommodate 3/16" brace thickness
Black silicone for vibration dampener on nuts and bolts (optional) and sealing fender (a must do)
As this is a first generation sub-frame mod, I am sure there will be improvements to this design by some adventure riding engineers. Please share you ideas, designs, and mods as it is apparent the TE 630 is a very short production cycle (2011) and there will be very limited after market support for the model. Feel free to PM me if you need any help if you do this mod.
Vince
Basically,
Parts/tools needed:
Sharpies pen
Punch
Dremel tool
3/4" hole saw
Vince
