TE stator upgrade 2007
Guiton
Hi everyone I'm after some advice, I have a 2007 TC250 fitted with electric start and a light kit, I have a feeling the standard TC stator has gone bad (Due to the extra drain on the electrical system) I would like to upgrade to the higher output TE250 one. Has anyone done this ??? I'm guessing I will need the TE CDI box to match???
Many thanks !!!
Stator for power is not the same circuit as the pickup for the cdi. I think the whole assembly is different and has more coils then the tc. You will need to buy the whole unit for the te and I think the flywheel. All this is not cheap. Get the parts manual and have a look.
The tc stator should be good enough if you have a good battery. I have a tc510 with the same setup and have no problems.
