TE to SM Conversion Issue
Guoseph
Hi all, attempting a TE to SM conversion on a 2008 TE 510. SM wheels are from a 2009 450SMR, rear rotor stock, front rotor is a Braking SK. Using a Warp 9 caliper relocation bracket (replaces part of existing bracket).
Front rotor doesn't seem to line up with the caliper (too far right, as seen sitting bike). There is a spacer that moves the rotor away from the hub, but then other parts start rubbing. Maybe I'm doing something wrong with the install, not sure.
I thought the TE and SM used the same wheel spacers/axles, please let me know if you have done this conversion and any wisdom you could share.
Thanks,
Alex
