TE to SM Wheels. Kickstand? Magnet pickup for speedo?
  • Thread starter Thread starter vespadaddy
  • Start date Start date
V
vespadaddy
Guest
I just finished bolting a pair of 2006 SM610 wheels and tires onto my 2008 TE450. While it has not been as plug and play as I had hoped, I test rode the bike today with the SM wheels, so I am nearly done. I ended up using the TE front brake caliper, with a caliper relocation bracket. I'll probably still work on mounting the SM caliper some time later.
My leftover issues: Kickstand. It sucked bad enough with the dirt wheels (stock), now with the 17's, the stand is too long. I don't have a welder. Any idea what stand I should buy that will bolt up, and work? Or should I just look for a triangle stand for the rear axle?
Speedo: There are no magnets on the street wheel's rotor, so the speedo doesn't work. I tried to use some super strong tiny magnets on the rotor, but the pickup doesn't seem to 'see' them. I had one placed where it would pass right over the screw in sensor on the caliper bracket, but it failed to pick up the magnetic signal. So I now have no speedo. Thoughts or suggestions?
Thanks!
you could probably pick up a SM kickstand and just use that all the time instead of the super extended stock TE one. Not sure for the spedo pickup.
If you know how much length you need removed from the stand, I'll cut and tig it up for free. PM me if interested.
I carry little 1x2 that I put under rear wheel to make bike taller and work with original TE kickstand :)
Thanks for the offer, oldskool63, but Tenn is a bit too far from MN, so I think I'll save the shipping expense and look for a local welder. That's a kind offer though, so thanks.
No problem Vespadaddy. It may be best to have it on the bike when you got to a shop. Cut off as little as possible and check it to your liking. It's better to makes a few cuts than whacking off too much and making 2 different welds.
