TE250 2011 BUSH QUESTION
jetmani
Hey guys,
Today I went for a ride and 2K's in my bike was making a weird noise, I think it might be a worn bush as there is excessive up and down movement on the front drive sprocket.
Number 26 in the image, Do these things wear out?
Or is there a bearing somewhere at the back which could be warn?
If you have up and down play at the front drive sprocket you need to have the counter shaft bearing replaced. Do not ride it like that cause when that bearing comes apart it will do a lot of damage. The cases need to be split in order to replace it. The reason it goes bad is from running the chain tension too tight.
If the counter shaft bearing has gone would it be leaking oil from the seal?
mine isn't leaking, I never have run a tight chain.
Could it be something else?
If the play is between the shaft and the case Id bet its internal bearing, if your lucky the sorocket has play on the shaft but you have to check whats going on to better diagnos it.
Yup!
What he said.
Check the countershaft carefully. it might be cracked as well. I've seen it.
If it helps at all, these motors are not too hard to take apart.
