TE250 2011 SPARK PLUG
jetmani
Hey guys,
Does anybody know how to remove the spark plug without taking the tank off?
I'm fairly sure I have done it before with a thin plug spanner and extension, but for the life of me i just can't get the spanner down the hole, it seems like there is some sort of rubber down there making it hard to get the spanner fully down.
I would not think you could do it if you have the bigger 2.5 gal tank.
On the 2010's with the small 2 gal tanks, you can check the valves with the tank on, but the new tanks take up the space.
I guess you got a wrench in there. I could not.
As you note you need a very thin plug socket to get into the hole in the valve cover.
Its gonna be tight.
In your case
There is rubber gasket that is grabbing your plug socket. You need a thinner socket.
