te250 electrical problem?
cycleman2009
Hey Ive got a 07 te250 that will not start using the electric start,but will start with the kickstarter,and run for a short time and die.recently rode a dual sport and rode perfect until i dropped the bike and after that it will not start unless i kick it.I put a brand new battery in it and no luck,any thoughts?
Question: Does the starter motor turn the engine over or is there nothing when you push the button? I had a case where a couple of wires running back from the main harness to the relay were frayed, also check your battery cables. The negative cable is prone to break at the battery if the battery is not tied in tight. I have heard of the start/kill switch failing as well. Check your fuses and connections under the tank. My friend currently has an issue with his '07 TE 510 where it will run for 5-10 minutes and then die, no spark...let it sit for a while and it will start, run and die. He's having it looked at, so I'll post when we find out the problem. Good luck and keep us posted on what's up.
On a side note, My TE 510 started running real rough about the same time I discovered the frayed wire to the relay. I did a whole bunch of work over the weekend, tore the main harness out and checked continuity,went through each wire, checked the stator, even took the carb off and cleaned it...turned out to be a fouled plug! Start simple.
