I've just replaced my clutch salve cylinder after I buggered when bleeding the clutch.. don't ask.. I just thought I'd better say as it was relevant info
Now I haven't put any dot fluid in until i get a syringe tomorrow to reverse bleed it, but the bikes in neutral so should start regardless yeh?
I have had this starting issue intermittently when starting the bike during rides. I get a click, or an electrical whining noise when trying to start the bike. I had the worm gear replaced as that already was buggered (factory recall on the 2012's). When getting this issue I am always able to kick or kill start it - kicking can be a pain, but probably my technique as I don't kick it regularly. I just put a new battery (SSB 220ca) in as the old one was borderline when I load tested it and I thought this may be the issue.
This sounds to me like the starter motor is buggered, but it's a pretty new bike that's not used very often - hopefully its a smaller/cheaper fix.
What's your thoughts guys? What can I check to confirm the issue? Thanks.
