Acquired a slightly used 2013 TE 310 . Has hi flow air filter cage ; O2 sensor removed ; Catalyst removed ; 6 inch exhaust plug ; 15/48 gearing . No manual for bike .
Engine hunts at idle and low rpm and flames out under throttle opening at low rpm .
Questions
1 : How can one determine what map is installed ?
2 : Is there a connector behind the headlight to change the map ?
3 : Is the stock ECM reprogrammable to any degree ? ( Kehine )
4 : If in a #2 map is the O2 sensor required or does it no longer matter ?
Been reading all the back and forth info on TPS settings so looking for clarification on the above questions .
Any info on the above questions appreciated . Please note :: 2013 TE 310
Thank you
Questions
Thank you
