TE310 Clutch Bleeding
ncgrecon
So I've had an issue with my clutch getting mushy. I installed the master cylinder rebuild kit but can't seem to bleed it and get any solid feel at the lever.
I've tried to back bleed with a syringe and it won't work. Almost like the line is blocked, but I know it is not.
In trying to figure this out I broke my slave cylinder by blowing the circlip out of the groove and cracking it.
Please help on how to bleed. I've tried everything and nothing seems to help. I'm already out $150 for the slave cylinder and don't want to have to bring it to the shop and pay any more.
Thanks!!!
Thanks!!!
Back bleed blockage: the m/c piston may be too far in, blocking the relief port... add some freeplay to the lever. Compare the new & old parts- maybe you have a slightly different piston. o-ring or cup may be blocking the port also.
take the line off at the m/c and back bleed from the slave cylinder. Then you'll know everything is good from the brake line down.
bleed (if you can) with the slave cylinder not bolted to the bike.
your original problem was probably up at the master cylinder.
good luck.
Have you tried bleeding it the old way... pump lever a few times, hold lever just off the bar, and release bleed screw for a moment, close... Repeat till line runs clean or without bubbles making sure reservoir is topped w/fresh fluid. I figure you could use the syringe too just drawing it down while topping the reservoir. Two possible fails is seal at reservoir and seal for slave in the case.
Take the slave cylinder off and with your hands pump the piston inside this will pump fluid through the line
Back out the master plunger adjustment screw, too far in will do what you said about ( something blocking it).
Later George
