I've considered putting tools in my skidplate. Where I ride in the southwest there usually isn't much water to worry about. I would think that you'd hardly notice the weight as it would be carried so low. I imagine there are down sides to this that some of you will tell me all about...
plus I've added a small radiator overflow tank in that location.
Yeah, I've been looking for a place to store a few tools too. On my '14 TE310R, I have a lot of wires & fuses on the right side.... plus I've added a small radiator overflow tank in that location.
One question: how do you remove the sidecovers to get at your tools? do you have an 8mm wrench somewhere else? (okay three questions) And are you worried about restricting the air into the airbox at all?
let us know how this works out.
It's not a bad idea (and it's been done) but you generally need a tool to drop most skid plates. A 1/4-turn fastener(s) might be a worthwhile mod if you do this.
Those are great ideas! I would have to come up with something else. I run a Nomadic Designs rear rack and you have to remove that to get the side covers off. Maybe in the little space behind the battery on the backside of the fender where you have your velcro (probably your tuner). I have been putting on my rear rack, but trying to keep the weight off that as much as possible.
The subframe is minimal with attachment points for the rack, and on my old DRZ, the rack kept breaking the subframe at the bolt locations. when I put a 1 gallon Kolpin on it.
Thanks for the link!There's a thread in the 610/630 forum where we talk about this problem and we've come up with a solution. Please, take a look:
http://www.cafehusky.com/threads/te-630-sub-frame-mod.22225/
I don't know if something similar can be done in the TE310. As I'm not planning carry any luggage on this bike, I've never thought about it
Regarding to the velcro, I used to fix there a small plastic box where I keept some chain links, that's all. But finallly, as to put the seat on the bike with this "idea" is more complicated, I carry the chain links on the backpack
Actually turns out that they make the braces for the 630.
Here is the link:
http://www.nomadic-racks.com/index....30-sub-frame-brace/p/18006588/category=976078
