I'm having an issue with my 08TE250 (Has an Athena 310kit).
The bike is idling irratically and stalling.
It normally idles around 2000 - 2200 but is jumping between 2300 back down to as low as 1400 then stalling.
I have included a vid of the bike idling in the shed, but it is hard to get the full picture unless im riding it...
You will notice the nuetral light flashes, which I was told a while ago that there was a problem with my neutral sensor. I don't know weather this is acutally true or not or if it is actually trying to show a fault.
I find the bike will run ok at the start off a ride but progressively gets worse the more I ride. I have checked out quiet a few different things which I will list below. It doesn't seem to happen in any particular circumstances, hills, flats, down hills, wide open, tight trails it does it all round! It is obviously worse at lower speeds when in more technical tracks and I find myself having to keep the throttle open a little all the time and use the clutch to alter my speed just to keep the bike running.
- Dealer tuned with ibeat and made the bike run leaner which helped for a few rides but the following week the bike felt like a slug and just ran like crap! I did get a new speedo and airbox fitted under warranty but I can't really associate these two with the issues im having.
- New sparkplug and checked out plug lead
- Battery terminals all ok
- all fuses connected properly
- checked over the wires (only visually) to see if there was anything obvious.. Found a broken brake light wire and disconnected headlight wire - fixed them up.
- Fuel hasn't changed and I use 98octane.
- Fuel pump is in place (cable ties are tight)
- Temp sensor replaced (thermo fan isn't swithing on but it was suggested to replace it anyway)
- Ibeat hasn't picked up any obvious errors... But the dam neutral light is still flashing!
- kill switch is sticking sometimes and doesnt fully realease out, but pump is still purging.
- Oil change including oil filter... oil was pretty low so needed to be done anyway.
- Flushed radiator and checked hoses.
- Thought it maybe the tank not breathing, so I changed back to a hose (had one of those bling cap things which suffocates the tank!)
After all that I took it for a test ride... Seemed to be idleing well and running ok for the first 5 minutes, got to the end of the street and bike just died pinned in 4th gear.. I rolled to the end of the street and then the pump wouldn't purge! Even after stuffing around with the kill switch and turning the key on and off 20 odd times! It eventually fired but wouldn't idle. I then pulled the pump apart again to make sure it was sitting in place ok and then played around with the kill switch...
Still no good!
Any suggestions?
- This vid I actually got a decent run for 55seconds... starts to play up after that and stalls at 2250. Idle screw was turned up and it was in gear.
http://www.youtube.com/watch?v=q_bTSEVDFwo
- This vid shows it hardly staying on at all unless I rev it.
http://www.youtube.com/watch?v=rulSYIqtvW0
-This 3rd vid shows a better indication over the other 2 vids above.
http://www.youtube.com/watch?v=u3qsECKBVg4
Still no good!
Any suggestions?
I'm putting more miles on starter and leg than bike.I sent the bike to same dealer to get tuned again after 150 miles with 310kit and showed them the two issues .they said they don't even use neutral lights when they ride so don't pay attention to it
