Te310 starter button not working.
bensl
After running no elec start for a while now I finally bit the bullet and installed the new starter gears to hopefully give me button power again. Problem now is when I press the start button nothing happens. No noise or clicks or anything. I'm guessing it's not getting any power as when I hard wire the starter it spins up.
Any suggestions on what might be the cause? I checked all the fuses I could find.
Cheers
Is there a safety switch on the clutch lever or somewhere else on the bike to keep it from starting in gear?
Unscrew switch at the bar and clean it up. I had brake fluid in the past dissolve the plastic button and seat. May be oxidized from non use. Maybe trace to the connectors to the harness.
cheers for the reply's. turns out it was a dodgy relay which i was able to swap out with my 610 and now all seems good. hopefully the elec start last a bit longer this time.
