TE449/511 rear Tugger/Recovery Strap mounting
9880sts
Hi all,
i am after some Pictures for the rear strap and how you Guys installed it on the bike..
Thanks.
I had a touratech one, but there was no room if you carried a tool roll on the rear. Now I have a nomad tank as well, there is no chance so I have taken it off.
Instead, I now have a luggage strap which is in a figure of 8 around the rear end, using the hole around the fuel cap as a means at passing it through. I keep it pulled tight when riding, but can lengthen it quickly when I need it, providing a loop on either side as required (or both if I am really stuck!)
would u have some pictures of the Touratech one ??
i cant and would not install a fueltank on the back, In the hard stuff with steep drop down that would come on the way. Most rides we do only 50km in 5-6 hrs.
I use Tugger Straps Front/Rear: http://www.thetugger.com/ order the Extra Long one for the 449.
The mounting location is not ideal. I wish it was further back, but it's the only large set of bolts tapped into the sub-frame.
Hi Cosmokenney,
this is no Subframe at all.
the Tugger one here is mounted to the FUELTANK !!! this is no good idea. have a close look. You mount on insets only. They are melted into the Fueltank hull. If they come off you might end up with a hole in the Tank.
Hi Cosmokenney,
Oh shit! Thanks man!!
