TE449 Cooling system issue
little_twin
I now have 150 mi on my new TE449, and I must say I absolutely love it. I do have one issue that has me a bit concerned. I rode 2 days over the weekend, and after letting the bike cool down completely I checked the coolant level in the rad, and was shocked to find that it had unbled pressure in it. I checked the over flow hose to make sure it was not pinched or blocked and it is fine. I rode it the following day and checked the rad again after the bike was completely cool, and again the cooling system was presurized. Has anyone else expirienced this, does anyone know what pressure the rad cap is on the 449/511?
I will now check my TE511.
Thanks for the tip.
I looked into this a little deeper today, and it apears as though the radiator caps pressure spring and seal are being preloaded agains the inside of the filler neck when screwed on. I put on a cap from one of my other bikes and will see how it works.
They are all supposed to do that, has to hold pressure.
I know they are supposed to seal tight to the inside of the filler, but this one seems to be putting a lot of added pressure on the spring mechanism that is supposed to release unwanted/excess pressure.
Normally I wouldn't be concerned, but the the bike is holding pressure over night after being ridden, and it is enough to blow coolant out the filler when the cap is removed
Ah, so this is a closed system, so, if the overflow tank is leaking the system will not pressurize / retain pressure and contribute to some of the overheat issues?
