Dangermouse449
Hi all.
I promised a while ago to make a video of the throttle shaft actions of the Kehin/BMW Double Flap system. I strapped on my Sony Action cam & ran it at 120fps slow-mo.
(This is a real-world test, not a dyno run)
In the video, you can see several times where the second flap heads to the 'closed' portion of its range while the main throttle is opening. It does this first early in the vid, right off idle at light throttle, this is one of the things that brought about stalling/flameouts on my bike!
This was my reasoning for removing the second plate from the shaft.
With everything slowed down, you can also see the designed in delay of the second shaft stopping the normal 450cc hit from occurring.
Keep in mind that the two shafts work in the same direction to open.
View: https://www.youtube.com/watch?v=7Vn_9JxDOz8
