Te449 Help!!!starts sometimes
johnjack
I have a 2013 te449 that 2 dealers cant seem to fix. The bike starts some days and i can ride it for a few hours...next moring the bike will not start? Weird? Great example is it starts then 2 hours later i cant fire her up? It seems like the weather has no factor..it randomly starts then a few hours later nothing..
The dealer check the valves and i put a new battery in..any thoughts??? Thanks in advance
I've been chasing a weird starting issue in my 2011 TC449. My bike wouldn't start using the electric start, but would bmp start. I checked everything I could think of, and the problem wasn't affected by being hot or cold.
My motor ended up having low compression. Do a compression and leak down test.
I have a TE511 2012 my problems were with the electrics. Mainly TPS Pug pin corroding. Got to it early and had no further issue's.. my suggestions are to go over every plug and check for water ingress and corrosion.
