Te449. IMS tank with Scott sub mount damper...
AllmanFan
Anyone know if these two will work together without having to mod the gas tank to make them fit? Scott rep said he hadn't heard anything about it not working but seems like there has been discussions on other dampers not really working out with this set up on a te. Any info would be appreciated. Thanks
Right now my 449 is doing Hare n Hound duty, but I think ultimately I'd like to make it capable of doing the TAT. With the extra weight up front, it will surely change the handling, but pretty sure it'll jam along better than a big heavy Beemer. Keep us posted Allman. Great music choice BTW
Ah.. You definitely have to setup your suspension to match the extra weight. Probably don't have to change the valving, but go up one or two springs to keep the sag similar.
