TE449 Lower Ring with Spring Help
F1000
2013 TE449, I'm trying to fit the cylinder back over the rings. The lower ring has a spring between it and the cylinder. Of course the spring fell out from behind the ring. Now the spring seems to big, it doesn't want to compress and allow the ring ends to come together. I have not forced it all. I have the ring off the piston, and I am just trying to fit it in the groove in the ring and see if it compresses, which it doesn't want to do. What am I missing?
OK I got it to go on the bike, with help of my wife. I rotated the engine with the counter shaft sprocket and it spins freeley, seems good. The shop manual shows the ring end gaps being 180 degress out of sync, which I did. It also shows the end gaps on the short side of the piston, which I did. I think I got it, now TDC, and install the head and cams.
