te449 maintenance
14te449
My bikes been gaining some miles and so far has been good to me. Any special maintenance these bikes take compared to a Japanese bike. Anything to look out for?
Change the oil a lot. Rear shock lower bearing needs to be cleaned and lubed regularly (the only way to do it is to unbolt it). The lower steering stem bearing needs to be cleaned and lubed. Better take care of the swing arm bearings too.
I always figure that they work in hostile environments and care for then accordingly. I change the engine oil after 3 rides and the oil filter every second oil change.
Twice a year I do the swing arm and linkage regrease and yearly the steering stem regrease.
Pay attention to your air filter.
One trick I use is every fuel fill up I put 2 cap full of 2 stroke oil in the fuel. It cushions the valves, assists with top end lubeing and believe it or not it acts as a fuel preserver.
