What is the max RPM for a te449 or te511?  Is there a factory rev limiter?
My bike seems to run out of RPM's at what I would guess is 7k-8k rpm or so. This just sounds a bit low to me. I hit what feels like a rev limiter on hard acceleration in 2nd and 3rd fairly regularly. Am I just pushing the RPM's too high? I read the airbox may be a restriction that artificially holds the RPM's down. I also read the JD Tuner can add enough fuel to boost the RPM, but the limiter feeling is still there even with my tuner installed. I know the dyno chart for Motosportz' te511 showed a big jump in available RPM after the tuner install though.
