domrvt
My bike wouldn't take the ECU flash so I went with a PCV. I had been having flame out, dead throttle, and hot starting issues. I ran the PCV with Zipty's Factory Race Map, and I have a stock exhaust with cat. The bike ran great with the exception of one incident.
I was going real slow in 1st gear for a while and it just shut down. I couldn't bump start it, seemed like the ECU didn't want to fire. I coasted for a mile or so downhill then got it to start. I'm going to assume it was overheating. Might need to add a second fan for that type of riding. I've seen mentioned that people carry a spare temp sensor; can this be swapped while the coolant is hot? I'm running XF by the way.
Some other general observations:
I tightened the chain to 5mm or as close as I could - that is really tight! Are you guys running that tight?
I filled with 1150ml of M1 10W40 and had no oil enter the airbox. I'm running the stock venting setup. Previously I had been running 850ml, so I was really expecting some oil mess this time.
Overall I'm pleased with the improved rideability the PCV offers. I didn't do any 3rd gear power wheelies as others have claimed. Not sure if that's due to my limp wrist or stock exhaust. Either way, the FMF 4.1 is up next for me. Waiting on backordered header parts.
