Zackarybay
Hi Guys
As from last Summer I am a proud Husky TE450 2008 owner and enjoying the bike in and around Madrid Spain.
The bike appears to have been reasonably well maintained but quite well used and the other day the gear lever return spring snapped. A friend and I removed the crankcase cover and removed the gear lever shaft along with the broken spring.
New spring was €3 so very little pain there, however fitting the new spring is what I need help with. Below I hope you can see how we have mounted the spring to the shaft.
... and all being well below you should be able to see how the spring needs to push against the pin.
However the spring exerts no pressure on the pin as it is spread wider than the pin is, and this leaves the gear lever as floppy as it was with the broken spring...
Obviously I have something wrong so any help would be greatly appreciated.
Anyone had this before and can help with how to place the spring on the gear selector shaft?
It can't be hard but for the life of me I can not think what it it I am missing....
Many thanks in advance.
Greg
Greg
