TE510 Gas Tank Shroud Threaded Inserts...Grrrr
SierraHusky
Looking for advise on how to remove the shrouds when either the factory or the previous owner over tightened the shroud fixing screws causing the threaded inserts in the tank to break loose and spin. What have you fine folks found to be a successful way to remove the screws such that the shrouds can be removed ???? If I don't cause too much damage I'm sure I can re-attached the inserts with a petroleum resistant epoxy.
Welcome to Cafe Husky SierraHusky
If you look at the top of the page you will see a search link. Typing in 'spinning insert' will bring up a couple of good threads worth looking at.
This one would be a good start.
Spinning insert solution
:cheers:
