Te510
dale01
Hey Guy's,
Can anyone help me i have a 2010 TE510.
Washed it today and took it for a ride, and now on the speedo it showing a fail signal.Can someone tell me what that signal means??
:confused:
Cheers Dale
Hey Dale,
If you used a high pressure washer some water might have reached inside the speedo. It might dry out by itself after a good run...might not.:excuseme:
If the code persists the only way to read it or for that matter clear it will be to get it hooked up to Ibeat. (At your local Dealer)
