Helgar
Well that's what I thought. I have a 2013 TE511 made all the upgrades and I love my bike well I just got my new supermoto wheel kit in now I can have the best of both worlds with one bike anyway put my wheels on went for a ride parked it for a while went to start it all that happened was solenoid click click hum Battery?, wiring?, starter? nope all checked out so I put it in 6th gear pushed back and forth with the clutch out to get the piston to move tried the start it again it fired up fine with the exception of and grinding noise but it stopped almost instantly and I went merrily on my ride today I go to start it again starter was very sluggish and would not start hooked up jumper cables it started then cut off I went to start it again and the starter just spun but not engaged took off the starter it was fine opened the side cover up OH NO the 6 bolts that bolt the flywheel to the freewheel had came loose and ground the stator and the inside of the flywheel to bits now I'm buying a stator/flywheel ass. 450.00, freewheel ass. 175.00, flywheel puller and insert 150.00
I guess I'm just sharing this experience because it is easy to check your flywheel bolts but expensive to fix when it goes wrong has this happened to anyone else?
